Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Een transformeerbare "laplet" in de Lenovo Yoga-lijn.
Why does my screen have small flickers?
Hi guys. I recently got a lenovo yoga 14 and ever since the set up, my screen has these small, box shaped flickers. I installed the nvidia drivers and sort of mitigated the settings, but that had almost no effect. They pop up every once in a while, and I am concerned. Can I fix this? Thanks. Ps, the screen only flickers a little, it does not shut off.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Filteren op:
It might be your connection check your cords are plug in right, or you just might need to clean the connectors . You also can go on to youtube.com to watch videos and see if they can fix your problems. I hope this helps.
Was dit antwoord nuttig?
1 Opmerking:
thanks, ill try looking on youtube and cleaning my connectors. I hope it works
door Deel
It sounds almost as the problem I had. When I typed an address in Firefox and the suggestions were showing, they kind of got blurred out by black boxes.
I tried installing the intel graphics drivers from intel, but they did not recognize the hardware.
So I installed the intel vga drivers from lenovos site and after that the problem was gone.
This was for the yoga 510-14 isk, but it might help.
Cheers!
Voeg je antwoord toe
Droneking246 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 19
Afgelopen 30 dagen: 31
Altijd: 983
