MacBook keeps shutting down
I have a MacBook Pro 15" 2011, I have a couple of problems with it:
When I connect the MagSafe power adapters cable I have to hold the power button while I connect it for around 5 seconds then it turns on and if I just connect it and press the power button once or if I leave and leave the MagSafe on the computer it doesn't turn on.
If I turned it on, but when it does turn on it turns on once with a black screen then it will turn off then turn on a couple seconds later and the Apple logo will pop up and the bar will start too load and about halfway it shuts off then turn back on and go through the same problem overtime I've tried every reset even with the battery off and the MagSafe connected so I'm not sure if its the battery or motherboard or what.
Please help thank you
Is dit een goede vraag?
4 opmerkingen
Can you install this gem of a free App: coconutBattery. Take a screenshot of the main screen and paste it here for us to see.
door Dan
Ok so it stays on without the hardrive but with the question mark folder but with the hardrive it turns halfway into the loading bar and the battery lifecindicator on the side don't turn on at all what could be the problem?
door Isabel M
Thanks for all the answers really needed the help in thinking of taking to geek squad make sure that's its the battery and buy it but also got one last question even when I disconnect the battery and turn it on without it and just plugged in to the charger it still shuts off halfway threw loading you still think it could be the battery?
door Isabel M
Boy it sounds like you have the trifecta!
That points to a logic board issue as well here. Be sure to get an estimate of the costs, you might find getting a new system cheaper than trying to get everything fixed.
door Dan
