Flashlight works when it wants to, randomly
Hi Guys,
Been having an issue with my flashlight on the iPhone 6. It works when it wants to. It seems to work 3 out of 5 times I do a hard reset, but stops working shortly after.
I had the screen replaced over a year ago, have had problems right around that time. Since then I have tried the following:
Updated to latest IOS
Restored to factory settings
Replaced back camera
Replaced ANOTHER digitizer
Ensured tight cable 20 times (if it were a cable issue, it doesn't explain why the light works but 10 minutes later after not moving it does not)
All with no luck. So.... Anyone with a recommendation?
Is dit een goede vraag?
Any signs of water damage inside the phone?
For example are the LCI(Liquid Contact Indicators) red or white? There are two stickers on the logic board. One near the top and one near the battery connector a.k.a lower end of the board.
Another sign is white and green corrosion marks on connectors and etc.
door Ben
I can't find the white strip on the lower end, but the upper strip (next to back camera is white)
No corrosion or green marks on connectors either.
Phone never had water damage either....
Even if it were water, isn't a new logic board like $10?
door Daniel Krauska
No. That $10 one is just the printed circuit board with ZERO board components on it.
door Ben
Gotcha... Regardless what else to check?
door Daniel Krauska
Just noticed, when you press the flash light button the back light will flicker but not nearly are powerful as a full flash light..
door Daniel Krauska
