Ga door naar hoofdinhoud
Repair guides and support for your LG TV.
1342 Vragen Bekijk alle
HDMI input on my 4k LG not working
LG flat screen 55uf645
My inputs
Is not working it said check I puts
Update (08/30/2016)
Yes tried all HDMI ports 4k only works on hdmi1
Is dit een goede vraag?
3 opmerkingen
Hi,
Can you prove that the device(s) that you wish to connect to your TV using a HDMI connection are working via HDMI by connecting to another TV? Have you tried using a different HDMI cable? have you tried all the HDMI connections on your TV?
door
yes used different TV, New HDMI cable, tries ALL three HDMI ports
door
can HDMI board be replaced
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Try removing all HDMI cables and then "remove" the power cord for about 10 minutes (powering off is not sufficient ). Then Plug in the power cord, then one HDMI cable and try your device that way.
Also, something to note there is a known flaw with these tv's that cause a spike on the motherboard that cause the HDMI ports to stop working altogether.
http://www.lg.com/us/tvs/lg-55UF6450-4k-...
Look under ratings and reviews.
Hopefully the reset will get you backup and running though.
The board replacement is not hard either though.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Thanks, the powering off for a few mins worked.
door
The solution sounds crazy but remove the main board and bake it in the oven to allow the weak solder joints to reflow, it will normally last about a year or two depending on use, when they go out again, repeat.
Voeg je antwoord toe
red6424 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 10
Altijd: 33,732
