Ga door naar hoofdinhoud
The Asus X555L is a low budget laptop that came out in May of 2015. The model depicted in these guides is X555LA-SI305041, an Intel Core i3 laptop designed to be affordable for consumers. Similar model numbers: X555LB, X555LD, X555LF, X555LI, X555LJ, X555LN, and X555LP
20 Vragen Bekijk alle
whether capslock is on or off on keyboard
'''how do i know whether capslock is on or off on my ASUS keyboard because there is no sign related to it
i am too confused
please help me
Is dit een goede vraag?
Score 3
9 opmerkingen
sala kaam hota h lkin khada he nh hota lodu laptop h
door
I have this problem too - why isnt there a light to tell you about num lock like there is for cap lock - have no ideawh at scroll lock does but page up and down never work.
door
what i mean is my asus has a light on the caplock key to show cap lock is on - doesnt yours?
door
Mine does not either. :-(
door
Mine neither. Big problem when you are entering a secret code...
door
4 commentaren meer tonen
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Hi,
Try the following:
Go to Control Panel > Ease of Access Centre, scroll down to Make the keyboard easier to Use
Check the Turn on Toggle Keys checkbox.
Click Apply > OK.
Now you will hear a tone when you press Caps Lock, Num Lock or Scroll Lock. Windows will play an alert beep warning each time you press the Caps Lock, Num Lock, or Scroll Lock keys. These alerts can help you prevent accidentally pressing this key.
Was dit antwoord nuttig?
Score 14
4 opmerkingen:
Thanks for the tips regarding the toggle key setting for caps lock
door
Thank you! It was exactly as described.
door
How to turn on this sound on ubuntu?
door
It was a very very useful tip.. as well in the background of increased need of complicated passwords, this option is very very useful... thanks for the tip
door
The best solution:
http://cli.jonaskohl.de/
Score 2
1 Opmerking:
Really HELPFUL little utility for folks w/ cheep laptops w/o keyboard indicators.
door
Voeg je antwoord toe
Shivani Nathany zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 35
Altijd: 41,197
