Ga door naar hoofdinhoud
Model A1347. Released on October 23, 2012. Core i5 or Core i7 Processor. Apple Fusion Drive.
error essential.pkg afte ssd installiation
Good morning, I added a ssd crucial to my mac mini, when I try to install el capitan I get stuck and I essential.pkg by mistake ..
Ram has never been dismantled .. when I start with the original hardisk the operating system starts without any problem ..
ssd initialized.
can someone help me
Is dit een goede vraag?
2 opmerkingen
Of course your Mac is fine with your original HDD because OS X is stored in there.
door
Can you give us the exact model of the Crucial SSD you put in also do you have a SATA to USB adapter like this one: Startech 2.5" SATA to USB adapter if not you'll need it to prep the SSD manually.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I solved it by installing a HD instead of a SSD
Was dit antwoord nuttig?
1 Opmerking:
Then it sounds like either the data cable is bad or the SSD you were trying was not compatible in someway. Often I see people forgetting to reformat their drive to GUID or they needed updated firmware on the SSD unit with this series.
door
Voeg je antwoord toe
Luca Ciclisti zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 6
Altijd: 1,875
