Ga door naar hoofdinhoud
Inexpensive 5 1/4" 4G LTE 2016 phone. Fixed battery, 2 SIMs, up to 64GB microSD.
20 Vragen Bekijk alle
blu life one x not charging
blu life one x has stopped charging...tried charging from a laptop, have tried multable charging cables...what should i do next?
Is dit een goede vraag?
Score 6
1 Opmerking
I can't find a battery replacement for this phone,; not longer available for this model so I can't recommend it. I had to buy a new phone, (Motorola).
door
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
Sent mine back to the shop, battery would show a percentage ie: 16% regardless if charged or not, and would never change untess unplugged, plugged back in, then it would show ie: 100% and never change... ...Sent it back with phone back cover (minus the battery and sdcard) they sent Me a new one the battery charged discharged just fine, and displayed properly... All was ok then...
Was dit antwoord nuttig?
Score 1
how do you contact their uk support centres - I bought mine from amazon uk?
The daughter board for charging is easily replaceable if it's damaged. The battery itself is glued on, but if it's bad you can easily pry it off and throw it away once it's discharged, replacements should be available on ebay.
1 Opmerking:
My Blu life one x2 is not taking a charge and I don't know what to do.
Do I need a new phone?
door
Voeg je antwoord toe
gascaps zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 3,329
