Ga door naar hoofdinhoud
The sixth-generation Volkswagen Jetta, known as the NCS (New Compact Sedan) during its development, was announced in the North American market in June 16, 2010.
19 Vragen Bekijk alle
2014 VW Jetta S Oil Change Bolt question
The bolt is on very tight, which way do I turn so so I don't strip the bolt?
Is dit een goede vraag?
Score 1
2 opmerkingen
@garrett28 you will always find bolts tighten by turning them clockwise and loosen by turning them counter clockwise . the only exception will be when the bolts are spun ( moving ) and require reverse threads to keep them from spinning off. Like kaniggit49 said "Righty tighty, lefty loosey."
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
James Garrett zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 13
Altijd: 906
