Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De Samsung Galaxy Tab 4 8.0 Wi-Fi, ook bekend onder het modelnummer SM-T330, werd uitgebracht op 23 april 2014. Het heeft een quad-core 1,2 GHz-processor en een 3 MP camera achteraan.
Android is starting... Optimizing app 1 of 1
This is what I am seeing on my tablet after I press the power button to turn it on. It takes 6 minutes before this disappears and I am able to use my tablet. Any suggestions???
Is dit een goede vraag?
Score 6
3 opmerkingen
I found a solution that need no flashing.My s6 edge plus behaved same way.I left like that because I did not want to lose some applications. On the third day it booted normal.
door Deel
Same problem. Solved by uninstalling Stopwatch & Timer app: Icon has rows of zeroes and is magenta on top row, green on middle row and white on bottom.
door Deel
Only 6 minutes? My Lenovo tablet takes 15 minutes "optimising app"
door Deel
Voeg een opmerking toe
6 Antwoorden
Filteren op:
Gekozen oplossing
Flash the Samsung firmware for your tablet via downloaded firmware from sammobile matching the model number and region of your tablet.
You need to do this with the tablet plugged in and booted to download mode. Instructions on how to do this are on every download page of every firmware on sammobile website.
This should fix your problem otherwise you need to do a factory reset probably.
How to flash Samsung Firmware: http://updato.com/how-to/how-to-install-...
Was dit antwoord nuttig?
Score 5
5 opmerkingen:
But why did this happen after 18 mos of use? Mine is the same, 6 minutes of optimizing.
door Deel
The only things I can think of are:
- Bad app installation
- Android System Software Update is not optimized apps properly.
door Deel
Hi Ben, I have the same situation with a Samsung 6 (cel phone not tablet), do you apply same web link shown above?
door Deel
Samsung Galaxy S6? Same guide applies to that.
This guide is for pretty much all Samsung Devices and tablets from 2011 and newer.
door Deel
The better suggestion for me is located below regarding BATTERY USAGE of the offending application...
door Deel
Het nuttigste antwoord
If you have Zedge, this is what is causing it.
I had also done other updates and thought it was Android System WebView as it started right after that had updated. Then I read it's Zedge and I've had that program for almost 2 years. I had restarted phone and was again stuck on "Optimizing", but for me each time it has been a good 20 minutes.
I uninstalled Zedge and it started right up, no Optimizing. Thanks for everyone who figured this out!
Score 7
3 opmerkingen:
Thank you .. A good answer.
door Deel
that was it.. ty
door Deel
that was it!! your the only 1 on google or anything thank you for sharing ♥️
door Deel
Full load your phone. Turn off, disconnect from AC. Start and wait for the optimization process to come to an end. Check settings>battery for app using most battery. Deinstall that and reboot.
Update (06/03/2018)
Solution is from crackberry forum.
Score 5
3 opmerkingen:
This is accurate, and mine was not any of the apps previously mentioned (my fitness pal), but I checked the battery and it had the most use directly after starting. I uninstalled it and now my phone starts without any 'optimizing'. Thanks!
door Deel
This was SMART...(worked for me and my tablet is an RCA, so should work for ALL TABLETS/PHONES)
I went into SETTINGS>BATTERY, then ignored SCREEN and ANDROID OS (which took up the most battery usage on my tablet. The next item on the list was HANGOUTS (which I don't think I ever use). So I went into SETTINGS>APPS and tapped on it, then clicked on DISABLE. When it finished, I rebooted the tablet and sure enough, the problem was solved. I then went back into SETTINGS>APPS and tapped on HANGOUTS again and ENABLED it. I then rebooted the tablet just to make sure the problem was solved and sure enough it was.
Thanks for the excellent suggestion!
door Deel
This is a genius technique, highly logical captain. It works and it makes sense. Thanks.
door Deel
It was Zedge. Removed and instantly fixed issue. Thanks.
Score 1
How can I remove any app when Android does not even start?
Score 1
The only thing that seems to help is uninstalling the Google update on the RCA Galileo pro, but I want the Google update. Everytime it updates even though I did a factory reset, we go back to optimizing. I don't know what to do
Voeg je antwoord toe
kltilton zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 63
Altijd: 47,104
