Ga door naar hoofdinhoud
Released in February 2012 by Garmin. The Garmin nuvi 2555 LMT has a 5-inch dual-oriented display, Bluetooth capabilities, lane assist, 3D traffic, and Guidance 2.0 software.
7 Vragen Bekijk alle
My GPS Reboots unexpectedly very often
My GPS always shows "lost external power" and reboots unexpectedly. But the cable works fine for my other Garmin GPS, and I reset the device to default, Still not working.
Please help, thank you!
Is dit een goede vraag?
Score 3
2 opmerkingen
Thanks for your reply,.
Yes, it's an original charger which works fine with my other Garmin GPS.
I think that's the problem of mini-USB too, any recommendations?
Thanks!
door
you can try to open the gps. i did it before and its not hard to do.. check the main PCB for the charging mini usb. when its loose you will have to solder a new one. check the cable's as well. cause i had a molten cable of the battery...
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
It is possible that the mini-usb connector on the back of the Nuvi may have failed.
Test the connector by gently wiggling it. If it feels loose, it is a an indicator that it may have become disconnected internally.
Is the red light from loading still on when shutting down and reboot?
It is a common problem to this GPS.
Is it an Original charger and cable?
Kind regards,
Kevin
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
ejilliantan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 6
Altijd: 873
