My GPS Reboots unexpectedly very often
My GPS always shows "lost external power" and reboots unexpectedly. But the cable works fine for my other Garmin GPS, and I reset the device to default, Still not working.
Please help, thank you!
Is dit een goede vraag?
2 opmerkingen
Thanks for your reply,.
Yes, it's an original charger which works fine with my other Garmin GPS.
I think that's the problem of mini-USB too, any recommendations?
Thanks!
door ejilliantan
you can try to open the gps. i did it before and its not hard to do.. check the main PCB for the charging mini usb. when its loose you will have to solder a new one. check the cable's as well. cause i had a molten cable of the battery...
door Kevin D
