Ga door naar hoofdinhoud
De Coolpix S7000 werd uitgebracht in 2015. De camera heeft 20x optische groothoekzoom, wifi-mogelijkheden en Near Field Communication (NFC).
Why has the camera locked up?
Camera is frozen. Screen is on (special effects/image mode) & lens extended. Camera will not turn off or respond to menu, playback or directional keys. What do I do to un-freeze /unlock it?
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Didn't see any answers, so I simply opened the battery/SD compartment and removed SD chip then battery. Put them right back in and everything is working again as it was before it locked up.
Was dit antwoord nuttig?
Score 7
12 opmerkingen:
I ended up trying this and it actually worked, thank you!
door
yes, it worked! Thank you for sharing your idea.
door
Thank you, that worked!
door
Thanks a mill...it really worked
door
This worked untill I try to zoom in and then it freezes again
door
7 commentaren meer tonen
The best solution is using a SD Memory Card with great data transfer rate, like Sandisk Extreme Pro 95MB/s.
After change SD Memory, the camera has not been frozen or made this issue! Hope it help.
Score 1
1 Opmerking:
My memory card is a SanDisk Extreme 64 GB with "45 MB/s" on the label. Is this really too slow for photographing my dogs in the Scene Sport mode of my Nikon CoolPIX P950? It may be time for a faster card.
door
Voeg je antwoord toe
Sarah Moles zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 31
Altijd: 11,405
