Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De Samsung Galaxy S4 Active is een robuuste versie van de Galaxy S4. Momenteel werkt deze enkel op het 4G LTE-netwerk van AT&T.
Getting around screen burn-in
My Galaxy S4 has a burn-in problem. It's good for an hour or so, but then videos become un-watchable, and I have to not use it for a while before it goes back to normal. But every now and then, when I re-boot, the colors appear duller, but much better than when it's all burned-in. This goes away after about ten minutes. Is there a way to force it to stay that way? Some kind of setting or app I can use?
Is dit een goede vraag?
Score 3
1 Opmerking:
I haven't heard of this issue before, but have you ever considered replacing the LCD? Your phone is older now, and I have the same model. I just recently had to repair mine. You can find a cheap LCD on ebay, but never get one that was refurbished. You may also want to get an S4 for donor parts, which is also available on ebay. Hope this helps!
door Deel
Voeg een opmerking toe
1 Antwoord
Filteren op:
I'd replace the lcd, pretty simple process, follow my teardown and you shouldn't have any issues Samsung Galaxy S4 Active uit elkaar halen
Was dit antwoord nuttig?
Voeg je antwoord toe
John zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 31
Altijd: 1,358
