Ga door naar hoofdinhoud
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Vragen Bekijk alle
iPhone randomly flips between mute and non-mute
My iphone 3gs randomly flips between being muted and being live without touching the switch. Very annoying and I;m missing a lot of calls. Can anyone help?
Is dit een goede vraag?
Score -1
2 opmerkingen
hi i have the same problem..
i just ordered and received the new mute butoon, which parts else do i need for solving this problem, or can i fix it whit juste the new mute button ?
door
if you only ordered the external button you may need to order the flex/ribbon as well. it is headphone/volume/mute and power all on the same flex.
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
This is the part you will need to replace.
iPhone 3G/3GS Headphone Jack Assembly
Its usually the actual switch on here that goes bad.
iPhone 3G/3GS Headphone Jack Assembly Afbeelding
Product
$14.99
Was dit antwoord nuttig?
Score 3
1 Opmerking:
+ you catch on to giving answers quickly
door
the ribbon needs to be changed that controls the mute switch, power button, headphone jack, and volume button. It's all connected together.
erika
Voeg je antwoord toe
Richard Barrett zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 3,106
