Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
iPhone battery 6 is compatible with the iPhone 6S?
iPhone battery 6 is compatible with the iPhone 6S???
And, iPhone battery 6 Plus is compatible with the iPhone 6S Plus?
I tried to place the battery iphone 6 Plus, in the iPhone 6S Plus, and the phone worked, but not sure is there any problem in using this battery.
Is dit een goede vraag?
Score 1
1 Opmerking
how does it worked? are the battery connectors matched with each other?
door
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
No, they are cheap enough. Just buy a new one.
Was dit antwoord nuttig?
Score 1
Het nuttigste antwoord
No, they're not interchangeable, their flex ribbon connectors are different.
iPhone 6S battery: http://www.etradesupply.com/apple-iphone...
iPhone 6 battery: http://www.etradesupply.com/apple-iphone...
Score 5
3 opmerkingen:
I'm sorry, but looking at the pictures, the connector looks the same.
door
After comparing both connectors look at the middle. The notch / indent or whatever it is called varies in size which should make it not fit properly.
door
I Also cannot put my iphone 6s battery back . is it possible for you to switch iphone 6 battery with iphone 6s battery
door
no it's not possible
Score 1
As @kaye74173 said it is not possible (i tried for the sake of this question). If you try to force in the battery connector it might end up breaking the connector itself or the connector socket
Voeg je antwoord toe
Universo Técnico zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 4
Altijd: 1,692
