Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
iPhone 6 Touch Screen not working.
So I have replaced the screen on my iPhone 6 but the touch screen does not respond unless the front camera pin connector is disconnected. Any suggestions?
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
Problem sorted purchased new front camera assembly all working fine now.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
Thanks for posting this. This is something I will definitely note down in future repairs for iPhone 6 screen replacements.
Chances are the front camera assembly ribbon cable was damaged in some sort of way as you've replaced it.
door
I agree I probably damaged on removal or refit. Just so strange how the phone touch screen worked without the assembly attached but didn't responded with. Live and learn I guess still chuffed on the amount of money I saved doing it myself.
door
Het nuttigste antwoord
Hey Nathan,
I'm an iPhone technician at Screen Fixed in Australia.
If the selfie camera flex, ambient light sensor, proximity sensor has been damaged it can mess things up with touch.
You'll need to replace that flex cable for the digitiser to function.
Hope my 2 cents helped.
Blue Skies from down under
Ben
Score 4
The large rectangle part of the ribbon cable with the rectangle metal thing did you tuck it behind the large metal plate or put it on top of it?
As far as I know it should be behind the metal plate sitting on the black part behind the screen.
Also where did you get the screen from?
I'm assuming you followed the disassembly guide here?
iPhone 6 Vervanging van het scherm
Score 3
@screenfixedau
Here's a horn you can toot.
Score 1
Voeg je antwoord toe
Nathan Howells zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 16
Altijd: 3,658
