Controller Port 1 doesent work
Hey Everyone,
I got a Dreamcast from Ebay, but the Controllerport A/1 doesent work. All the other, B/C/D works perfectly.
I hope you can help me
Is dit een goede vraag?
Hey Everyone,
This guide would be the easiest, if you don't want to solder it
Sega Dreamcast Controllerpoort vervangen
This guide would use a little more work, but you could individually change out one controller port
Vervanging van de controllerpoort van de Sega Dreamcast
Also found this on eBay
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 24
Altijd: 1,885
3 opmerkingen
Do you know how to solder? If you don't, your best bet will be to purchase a replacement controller board off ebay and simply swap out the part.
door Ben Eccles Deel
yes i can solder, but why?
i read a lot of the problem on the internet, but that is always all controller prots, not only one. so i think the problme withe the fuse coulnd't be
door thunderblrd Deel
The reason I ask is that controller port board on the Dreamcast is among one of the more friendly parts for soldering, since all the components are through-hole. I would do a continuity test on the fuse, just to rule it out as a problem.
