Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
1233 Vragen Bekijk alle
After a succesfull screen replacement , screen top seems unresponsive
I replaced an iPhone 5c screen for a friend a days ago. Since I was installating it, I had some dead response from 3 different screens. I reconnected the original screen and it work flawless. I tried with a fouth screen and it starts working well until yesterday that my friend call me and told that the top side of the screen was unresponsive and it has a little crack on it (?!).
When I installed the screen in the final assembly, when you put the screen into de phone body, it was no easily assembled.
I did remove the red plastic protector from the back of the screen and cleaned the connector of the motherboard but nothing seems to work.
Any ideas?
Greetings from Mexico.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
I would suggest unplugging it and plug it back in again, I've had that issue before where it was unresponsive or there were some white lines going through. Usually that does the trick. If the previous screen is working fine and the new one is having issue then we know where the problem lays.
Was dit antwoord nuttig?
Voeg je antwoord toe
Miguel Nava zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 39
