Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6S Plus that was released on September 25, 2015. Model A1687, A1634
1041 Vragen Bekijk alle
Cables on the bottom of the logic board.
Does anyone know what the cables on the bottom of the logic board are for on and I phone s 6 plus? Their are two of them that run along the side of the board on the SIM card side that are not visible unless you remove the board and turn it over. Thanks
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
I don't see the question. If you are asking what they are for, they are for cellular diversity and GPS.
Was dit antwoord nuttig?
Score 1
3 opmerkingen:
Yes I am asking what they are for. I'm not quite sure what cellular diversity means. It is a 6 s Plus phone. thanks for your help.
door
I think he means diversity in different 3G and 4G (or is it called LTE) frequency bands as they vary across cellular networks and countries.
door
Cellular diversity is the secondary antenna for cellular signals, improving reception and provides MIMO capabilities for faster downloads.
door
@cray lets clarify what phone you are talking about. An iPhone 6Plus or a Samsung Galaxy S6? The only cables that you would have running along that area on an iPhone are the antenna cables. Check this teardown for the cables. Just in case you are referring to an iPhone 6s Plus check this teardown.
iPhone 6 Plus Afbeelding
Handleiding
Demontage van de iPhone 6 Plus
Moeilijkheid:
Gemiddeld
iPhone 6s Plus Afbeelding
Handleiding
Demontage van de iPhone 6s Plus
Moeilijkheid:
Gemiddeld
Score 1
3 opmerkingen:
It could even be a iPhone 6S plus.
door
@benjamen50 you are absolutely right. Good thinking ;-)
door
Sorry all its a 6s plus.
door
Voeg je antwoord toe
Corlene Ray zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 147
