Ga door naar hoofdinhoud
Repair guides and support for the 5th generation Honda Accord coupe, sedan, and wagon.
87 Vragen Bekijk alle
I have to mess with the gear shifter while starting it? Why
I couldn't start my car, after putting it on a battery charger it started. It didn't work with regular jumper cables and vehicle. So I bought a new battery, still didn't start, I mess with the gear $@$* pushing it forward ( it is an automatic ) and holding it their while I try starting it, and it works. But why, why is it doing it how can I fix it and what caused it?
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Will the car start in neutral? If it does then @oldturkey03 is probably right but you may also want to check the shift lock as this can also cause problems when starting
Was dit antwoord nuttig?
Score 2
@marshajo13 when you say pushing it forward, do you mean further into the "P" position? It does sound like a bad or misaligned neutral switch, You'll have to check it out. The switch is located in the central console. It is number 2 in the drawing.
Score 1
Voeg je antwoord toe
Marsha Sanchez zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 10
Altijd: 423
