Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
Short circuit in iPhone charger
Hello,
The sequence of events: Came home with a dead phone, see two new chargers on the table (brother got from Aliexpress),and quickly putit to charge. I left phone to charge. After aprox. 2 hours of charging I took phone in hands and see that it charged to 100% and in the mean time I pressed home button and something happened in the wall socket where it was plugged in. It sparked and smoked a bit, so I quickly put the cord out.
It looked like everything is normal, but since then my phone is not charging, because it always shows '' This ACCESSIORIES may not be supported '.
That charger was unfortunately fake, but even if I use my original it shows the same.
Now it can be charged only when it is switched off and battery empty very quickly.
But it is recognized in itunes normally.
I changed the battery, restored it, clean up dock connector, tried restart it, etc. etc.
The phone is no longer under warranty.
Does anyone have any idea what could I do?
Thank you to everyone who could help me,
Andraz
Is dit een goede vraag?
2 opmerkingen
I will try and report how things will go. Thanks for help
door
Hey everyone, i'm new here. So, i want to know the next. Today i was about to charge my iPhone, and when i plugged in my apple charger into the electric current, and it made a short circuit! it lighten from inside and started to smell like burned wires and won't work, the phone was connected and is not waking up
door
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
I guess you could try replacing the dock connector and try using a quality phone wall charger and lightning cable.
Was dit antwoord nuttig?
Score 1
If replacing the dockConnector doesn't help, it is likely a problem with the charging circuit on the logicboard. You will need a real professional to replace therevalent chips.
Score 1
How to check i phone 6 charging port shorting
Marta dump-truck in the flesh
Voeg je antwoord toe
Andraz Reich Pogladic zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 53
Altijd: 11,472
