Wi fi has turned off
How do I manually switch the wi fi back on. The computer is not picking up the signal. All other devices in the house are.
Is dit een goede vraag?
1. Press FN + F8 key...This should turn wifi on and off manually. or....
2. A- Go to control panel and select "Network and Sharing Center"
B- Select "Change Adapter Settings"
C- Right click on your WiFi Adapter and make sure it is Enabled
If none of these work, you may have a driver issue with your Wifi card.
Was dit antwoord nuttig?
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 28
Altijd: 4,808
