I cannot switch it on after replacing the batteries.
Hi, I replaced the batteries in my trackpad and it won't switch on now. I may not have switched it off before opening the battery compartment but not sure.
Phill
Is dit een goede vraag?
Phill
@phill if it worked before you replaced the batteries, you want to make sure that you have good batteries inserted. Exchange them once more for new ones. Observe the polarity and make sure that you insert the batteries correctly, check for any debris.
Was dit antwoord nuttig?
I assume that the Magic Trackpad you have is the generation before the current one. In that case it doesn't matter if you pressed the on off button before you took the batteries out because it resets once there is nothing powering it. You could try cleaning the contacts in the battery compartment (with a screw driver). Just rough up the contacts a little. There might be some battery acid or corrosion on the contacts. If it still doesn't work make sure you have good batteries and you put them in the correct way. If that doesn't work it's probably a hardware problem and you could either get a new one or take it to the Apple Store and they might be able to fix it. Best of luck!
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 4
Altijd: 123
