Ga door naar hoofdinhoud
In August 2000, the ninth-generation Corolla was introduced in Japan, with edgier styling and more technology to bring the nameplate into the 21st century.
20 Vragen Bekijk alle
How do I fix a refrigerant leak in the ac?
My a/c line has a leak in it and I'm trying to fix for as cheap as possible. Any help would be appreciated.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Logan Winward you still have to determine where it is leaking and which line it is. Once you find the leak, there is usually no way of fixing it (unless it is a gasket or O-ring, which is unlikely). Most of the time it will require the replacement of a damaged AC line.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Logan Winward zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 138
