problem with xerographic system
How we rectify problem with xerographic system
Is dit een goede vraag?
- Xerox 5755 geographic failt and paper jam left door
Sent from my Che1-L04 using Tapatalk
- Hello,try chg the cleaning motor for main charge.this motor located at rear main motor
- Try another drum. Clean transfer unit. Remove ALL trays and BE SURE NO paper or debris behind trays and up in top areas. log into diags mode and clear codes then let it fail then go back in and look at code. Trace code and you will find problem and fix.
- Reporting your fault codes would be a help in troubleshooting. For example, if the xerographic faults are occurring with 9-060 faults, you could have a faulty High Voltage Power Supply or poor connection on the board.
- Originally Posted by ExokÂ
sir i have this issue then i changed 4b unit (blue handle unit) and also i have installed stabilizer but stll now i have these issue with error code 9-560 what to do please help me
- Xerox 5755 foult code :- 03-480 power supply foultÂ
03-777 sip recovered form an uncontrolled power loss
how to solve this problem dear frds.......
May i change new power supply unit but the action is continued...........same foult
and service full machine.......at one by one all part.....
And i replace the power supply change with other machine that are work perfect and complete
Was dit antwoord nuttig?
Did not open completed .it show only starting screen disply
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 35
Altijd: 7,436
4 opmerkingen
how we rectify problem with xerographic system
door Dharmendra Pandey
Plz help me xerographic fault
door ali
Please help me xerographic fault Xerox 5755
door ali
xerox workcentre 7835 "altboot" full driver
door Bharti Xerox
