Ga door naar hoofdinhoud
IBM is the pioneer company of the modern PC
82 Vragen Bekijk alle
Why do coloured,vertical stripes appear on my R52 Thinkpad screen
Almost 5-7" of the laptop screen gets covered with thin vertical lines on starting the computer.Lines do not appear when adapter is used to connect laptop to another monitor.Is this a 'display' or a LCD problem?Please advise what can be done?
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
4 Antwoorden
Het nuttigste antwoord
This is LCD screen failure. You'll have to replace the screen.
IBM/Lenovo laptop repair guides.
Was dit antwoord nuttig?
Score 1
Those are raster lines and if the lines are there all the time or intermittent but in the same location it is an indication of a bad panel. The panel driver can also be the cause of this symptom. Some panels have issues with the connector that carries the signals. So check your wiring, connections etc. Your video card itself seems to check out since you have no issues with an external monitor. If none of this resolves your issue, follow LaptopRepairGuy's advise and replace the panel. Good Luck
Score 1
how to repair vertical line in my ibm thinkpad g41
1 Opmerking:
saubhagya, are you asking how to fix it? See Laptop Repair guy comment as well as my own. http://tim.id.au/laptops/lenovo/thinkpad... shows you how to approach it. Good luck
door
I had thin red vertical lines on my screen of my T430 Thinkpad. I solved this by disconnecting and blowing air on the connector and reconnecting the screen cable just next to the right hinge
Voeg je antwoord toe
Harry zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 21
Altijd: 5,308
