Ga door naar hoofdinhoud
Repair guides and support for the ZTE n817, also known as the ZTE Quest.
70 Vragen Bekijk alle
Where sim card. goes
Where does sim card go
Is dit een goede vraag?
Score 11
10 opmerkingen
I have this problem too. The phone keeps telling me to mount an SD Card. And... I have no clue what that means or how to do it!
door
You can add a MicroSD card up to 32Gb to the phone. Put it in the slot above the battery inside the back cover.
door
i need to find the sim card in this phone any help i can get will work thanks!
door
How do I insert y sim card into my zte n817
door
I was wondering if you could put an SD card from a smaller Trac phone to a slight bigger Trac phone?
door
5 commentaren meer tonen
Voeg een opmerking toe
9 Antwoorden
Het nuttigste antwoord
No Sim card on cdma phone...n817 is a cdma phone
Was dit antwoord nuttig?
Score 6
6 opmerkingen:
They didn't ask about a sim card. they asked about an sd card which is memory.
door
Yes,the answer was helpful in getting a good morning laugh aahhhhaha ha oohhhhaha dang! That was goodthat whole conversation was short,polite and hilarious ...Thanks
door
Thanks, this answer was very helpful.
door
This answer is incorrect. Some versions of the N817 use GSM, while others do not, including Lifeline phones.
door
@jmredingtx You are incorrect. The OP, Daniel, asked about SIM cards, not SD cards. You responded to a different person, timday365, who added a question about SD cards. Most others also asked about SIM card, but a year after your response, Maria Swope also asked about SD cards, but it was a different question - it was about migrating.
door
1 commentaar meer tonen
There are 2 types of cellphone technology: CDMA and GSM.
GSM uses a SIM card on phone carriers like AT&T, T-Mobile, Rogers, etc.
CDMA cannot take SIM cards and relies on an ESN number inside the phone. Carriers such as Sprint, Verizon, Boost Mobile, etc. use CDMA.
You cannot switch between GSM and CDMA carriers on this phone.
Here is the manual for the phone.
https://zte-iqorsupport.custhelp.com/ci/...
IF it is a CDMA, there is no SIM slot.
If it is a UTMS/GSM/LTE, the SIM slot is above the battery.
Score 3
3 opmerkingen:
@oldturkey03 I don't get it... What's wrong with this answer?
door
@pccheese those are the right facts. Ask yourself this, does it answer the original question "Where does sim card go?" The answer given by "Alex cruz" is specific. Now if you do some research on the device and you see that it is listed as having a Sim card slot. http://www.imei.info/phonedatabase/91927...
door
Sorry I'm waiting at the DMV taking forever, a lot of time I have ATM lol
door
The Sim-card is located inside the ZTEN817
Turn your device off prior to opening (from the bottom), once open one can then insert the sim card in the slot provided just above the battery.
To install one must first remove the battery.
That's it!
Score 3
2 opmerkingen:
thats for an SD card moron, not a sim....sheeeesh
door
Hey Malfunction Junction, I guess you malfunctioned, because the OP asked about SIM cards, not SD cards...Which only some versions of the N817 have.
door
Underneath the battery. ZTE confirm use of sim card in this phone.
Score 2
1 Opmerking:
Only some versions of the N817 can use a SIM card.
door
This phone does not take SIM cards.
Score 1
1 Opmerking:
If you are referring to Lifeline phones (free phones), that is true, but other versions of the N817 take SIM cards. It's listed in the specs.
door
This phone don't have this.
1 Opmerking:
Some versions of the N817 have it, but Lifeline versions don't.
door
I’ll try again. Please read S W’s answer, as it was the correct one. Alex Cruz's answer is incorrect - GSM is shown in the normal specs for the N817 - but the Lifeline version does NOT have GSM as the government doesn’t want people putting a SIM into a free phone to effectively steal it.
If you follow Jo Anne’s instructions and find a SIM card slot, you have the regular N817. If you don’t, you have the other version, used for Lifeline phones. If you research it, you’ll find out it’s true.
Where does the SIM CARD GO ON A 2013 MODEL Q LINK ZTE N817?
where do you find the sim card on a zte q link phone
Voeg je antwoord toe
Daniel szasz 9329 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 23
Altijd: 42,131
