Ga door naar hoofdinhoud
Model PowerBook 1400 Series. Released October 1996
PowerBook fails to power on at all?
A friend is trying to power on a old PowerBook 1400cs/133, but to no avail. I'm having a bit of a tough time trying to diagnose what could be wrong with it, as I've never operated on one of these PowerBooks before.
RAM, HDD, and battery all seem okay.
Is there anywhere specific I should be looking at (DC-in, connector?) to perhaps further diagnose this issue?
Is dit een goede vraag?
Score -1
2 opmerkingen
Any corrosion or burns (short) evident on logic board? check cable/connector end to on button
door
My 1400 starts every time when I hit the small reset button on the back, the tiny button between the two inputs on the right.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Try using a multimeter to test the output of the AC adapter. Ty resetting the power manager again with the battery removed and power adapter disconnected. Press/hold the reset button between the ADB and serial ports for 30 seconds, then connect just the power adapter and start up. Do you get anything, noise, or lights?
Reset the PMU, heres how: http://support.apple.com/kb/HT1781?viewl...
Was dit antwoord nuttig?
Score 3
2 opmerkingen:
I can't remember Richard--does this unit have a PRAM battery? +
door
Resetting the machine via the reset button isn't working. I suspect that the PRAM battery may be totally done for. I managed to order a new one, so when that comes, I'll have an excuse to crate a repair guide for this model for iFixit. :)
door
Voeg je antwoord toe
LambdaCalculus zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 10
Altijd: 2,244
