Ga door naar hoofdinhoud
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
573 Vragen Bekijk alle
Upgrade Internal Hard Drive
Hi,
I have purchased an iMac (Retina 5K, 27-inch, Late 2015) - Very basic one with default 1TB WD HD. No fusion, no flash storage.
I'm thinking to replace the 1TB WD HD with an SSD from OWC. I also heard the PCIe slot is unpopulated in my iMac. Anyone know if I can purchase any flash stick to plug in (if it fits)? The original purchase is not Fusion so will it show 2 SSD drives in the OS?
Beside the flash storage, what is this PCIe port capable of? Does it work with any PCIe components (cards) for other usage purposes?
Thank you.
Is dit een goede vraag?
1 Opmerking
Here's the full specs of your system: iMac 27" 3.3 GHz i5 5K display (Late 2015)
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
PCIe connector in your system is a PCIe 2.0 x 4 Lane NVM Express interface. Sadly it takes a proprietary Apple SSD unit. The SSD blade drives Apple offered was either a 128 GB, 256 GB, 512 GB or 1TB.
The larger sized SSD's are hard to come by for sale on the open market, you will likely need to order a spare unit from an Apple authorized servicer, I worn you it will be expensive! The other option here is seeing if the just released 3rd party SSD from OWC will work in your system.
As for swapping out your current HD for a SSD. While that is possible you will need to get an adapter frame as your current drive is 3.5" while the SSD is 2.5". In addition your system leverages a builtin thermal sensor within the HD. You'll need to replace it with this adapter from OWC: OWC In-line Digital Thermal Sensor for Hard Drive Upgrade for 27" iMacs 2012 and Later in addition to the SATA SSD unit.
The newer Thin series systems are much harder to open and you do run the risk of damaging the display assembly if you don't follow the IFIXIT guide: iMac Intel 27" Retina 5K Display Hard Drive Replacement or if you dare: iMac Intel 27" 5K Retina-scherm Vervanging van de blade SSD
Remember the PCIe blade interface is much faster than the SATA III interface and the Thunderbolt II interface is also faster than the internal SATA port.
Frankly, I would not take the risk here and besides, the larger SATA SSD's are still quite expensive! I would go for an external Thunderbolt 2 RAID unit like this one: ThunderBay 4 Mini. It will offer better performance than the SATA SSD and offers less risk.
iMac Intel 27" Retina 5K Display Harde schijf Afbeelding
Handleiding
iMac Intel 27" Retina 5K-scherm Vervanging van de harde schijf
Moeilijkheid:
Gemiddeld
1 - 2 hours
iMac Intel 27" Retina 5K Display Blade SSD Afbeelding
Handleiding
Moeilijkheid:
Moeilijk
2 hours
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Tony zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 670
