Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
20 Vragen Bekijk alle
No service on phone but ICCID shows in About
I've got an iPhone 6 where it constantly looks for service.
I've tried 3 different sims.
The SIM card shows in the ICCID field under Settings > About.
I've swapped the logic board into a new phone case\shell where that housing\cellular previously worked, however, I still get no service.
Is cellular service linked the the logic board somehow?
Is dit een goede vraag?
Score 2
8 opmerkingen
Is your phone locked to a specific carrier?
door
I don't believe so, is there a way I can check? Searching via google only brings up those scams to pay for unlocking service.
door
Well I use sim-unlock.net to check these stuff. Costs like $5 to check via imei number so I don't recommend doing though.
door
Is there really no other way?
Boggles my mind to be honest. The old school symbian OS nokia phones were a dream to work with compared to these. :\
door
You have checked that the date and time is correct on the phone right?
door
3 commentaren meer tonen
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Of course the cellular service is linked to the logic board, why else would you put a logic board in a phone?
It is likely to be dead power supply to the transceiver chip, or dead transceiver chip.
Was dit antwoord nuttig?
Score 5
6 opmerkingen:
I've noticed that the cellular antenna is in the charger port piece.
This makes me curious if it's something else, somewhere else.
door
Are you able to go into a little more detail re~ transceiver chip?
door
There are 2 cellular antennas, it is not possible for them to fail at the same time.
So it must be a chip problem.
door
Hey Tom Chai, are you able to locate these for me? on a schematic or diagram?
door
Basically every chip on the lower half of the board, it's way too complex for ppl without the experience or tools.
door
1 commentaar meer tonen
Check IMEI via *#06# and if no IMEI is displayed then you have a issue relating to baseband chip.
Score 4
In "about" do you have an IMEI number?
Score 2
11 opmerkingen:
Yes I do have an IMEI in Settings > About.
It does does all detect the sim as it shows the ICCID
door
I've come across the same issue, this is usually due to the housing you've used. I found personally that using an aftermarket Housing is the wrong move, use only an original / OEM Apple housing if you can and you shouldn't have the issue.
door
I've used a legit apple housing?
I'll try testing with a different iPhone 6 housing (OEM apple) and test to see what happens.
door
From what I've been told / seen, and what the research suggests, there are no Original New Housings available for purchase / use, only second hand and maybe A-Grade aftermarket? That's just what I've found in my experience
door
Ahhh Sorry, I meant I've used housings from broken screen phones where the logic board has been removed but everything is in tact (sometimes screens are missing too)
door
6 commentaren meer tonen
Voeg je antwoord toe
Nigel zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 3,793
