Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
betaalbare notebook met ten minste basis gaming-kracht, inclusief de modellen G50-30, G50-45, G50-70, G50-80.
How to change cpu and gpu?
how to change my lenovo g 50 cpu and gpu?
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
4 Antwoorden
Filteren op:
Het nuttigste antwoord
You can not change the CPU and GPU in this laptop....
Was dit antwoord nuttig?
Score 1
If these are diagnosed faulty, they can be replaced with exactly same models using specialised soldering equipment, however they are most likely non-upgradeable due to high firmware and BIOS integration.
Score 1
CPU and GPU in this laptop are fixed , hence you cannot change them.
Score 1
I suggest attempting to reset the cmos on the motherboard via a jumper labeled pwr cmos, power jumper or just plainly, a big shiny flat yet round coin style battery. There are lots of tutorials on that topic with more info than I care to share here. Good luck!
3 opmerkingen:
And how is this related to the question?
door Deel
If you are limited by firmware settings and bios settings you can reset the cmos in order to bypass them. Then you could try a different chip. Sorry, I’m tired.
door Deel
In other words, reset the cmos by taking the button cell battery out.
door Deel
Voeg je antwoord toe
nazri12330 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 16
Altijd: 2,068
