Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
Touch and power button issues
Having some weird problems after replacing the screen on this iPhone. To start the screen did not work at all when I received the phone. During the repair I tore the cable that the home button connects to. I replaced that cable and now after replacing the screen the touch almost never works. I can try to swipe over to the unlock screen but it will only swipe over once or twice every 30 attempts. Also the power button sometimes just doesn't work at all and sometimes it works fine. Currently I'm going over the mother board looking for any damages but so far I have nothing. Anyone have issues like this before or know of a solution? I tried a completely different screen and the same problems are happening.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
The touch problem sounds a lot like a common problem in the iPhone 6 (plus), where the touch IC no longer makes proper contact.
Unfortunately the only permanent fix is to resolder the entire thing, which requires quite some expert skills.
It's kind of hard to find decent info on this problem, since Apple won't acknowledge it.
For more information on what exactly causes it and how to fix it: http://mendonipadrehab.com/entries/gener...
Was dit antwoord nuttig?
Score 3
2 opmerkingen:
Definitely a good read. Thanks for posting that link
door
Thank you so much for your help time to test my soldering skills
door
Het nuttigste antwoord
Clean the digitizer and lcd sockets with 90% isopropyl alcohol. Make sure you've secured your connections and make sure you're using quality parts
iPhone 6 Plus Screen Replacement
I would also check and see if the phones been water damaged. That would also be a 90% isopropyl alcohol clean. As for the power button. Try to clean it, you may need to get another flex cable
iPhone 6 Plus Home Button Link Cable
iPhone 6 Plus Power Button Replacement
Replace a screen compatible with iPhone 6 Plus. Includes all of the small parts preinstalled in the assembly. Features a 5.5 inch 1080 x 1920 pixel IPS LCD Display, Front Glass Digitizer Panel, Front Camera Assembly, Earpiece Speaker, Home Button Link Cable, and LCD Shield Plate. Afbeelding
Product
$49.99
Replace the cable that connects the home button assembly to the logic board compatible with the iPhone 6 Plus. This cable follows a channel in the LCD shield plate. Part #821-2658. Afbeelding
Product
$14.99
iPhone 6 Plus Screen Afbeelding
Handleiding
Moeilijkheid:
Gemiddeld
1 - 2 hours
iPhone 6 Plus Power Button Afbeelding
Handleiding
Moeilijkheid:
Moeilijk
45 minutes - 2 hours
Score 3
2 opmerkingen:
Power button is working fine after giving the it a good cleaning
door
Oh, good! Glad you got it sorted
door
Voeg je antwoord toe
Jeremy Byers zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 14
Altijd: 2,395
