stays black when you turn it on
my computert stays black when you turn it on wwhy
Is dit een goede vraag?
K SEARS could be caused by a bad backlight, bad LCD panel or bad GPU. First thing you want to do is to attach an external monitor. If you have a proper image with that you know that your GPU is ok (motherboard). Then focus on your LCD. Check with a flashlight by shining it at an angle against your LCD see if you can make something out. That would be a failed backlight possibly caused by a bad inverter. Check on here how to fix it. You can also download the service manual from here which will show you the inverter as well as LCD replacement procedure.
Was dit antwoord nuttig?
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 15
Altijd: 95
