Ga door naar hoofdinhoud
The Motorola Droid 2 (A955) is the fifth phone in Verizon's Droid line.
How to repair if Radio Reciever burns out?
The WiFi would freeze when showing it was turning off which started causing phone to turn off & back on by itself but would freeze on reboot. Had it reformatted, but still keeps shutting off & on after about 10 minutes. Stays on Airplane mode so cant make calls. Was told was from wireless radio/receiver was burnt out. Is this difficult to fix? What would need to be done?
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
I believe this transmitter is part of the main board and is not user-replaceable. You may need to replace the whole mother/LogicBoard.
Was dit antwoord nuttig?
1 Opmerking:
Then wouldn't that actually be easier?I am getting different explanations from people.*it's the software that was used to flash it, *Its a hardware issue,*no, it's a software issue that whoever flashed it should be able to fix it *or we can do for $120,*we have "special droid flash software" that will correct all of that". This is worse then a crossroad. I have no idea which direction I should follow??
door
follow your heart...
Voeg je antwoord toe
lizrfresno325 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 5
Altijd: 1,381
