Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De Nikon Coolpix S33 Waterproof Digital Camera B00T85PKD0 is ontworpen als een camera voor alle doeleinden die waterbestendig, schokbestendig en vorstbestendig is.
Saving multiple pictures to one folder
We take pictures on our new Nikon Coolpix S33 and turn off camara. When we take the next batch of pics, these are saved to another folder. By the end of the day, we can have 50+ folders. Our older Coolpix did not do this. We would like the days worth of pics saved to one folder on the SD card. Any suggestions?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
According to the reference manual for the S33, the camera does not behave in this manner. It numbers files continuously from 000 to 999, and creates a new folder only when it rolls over from 999 to 000. Only when the interval timer is used (a mode of operation where the camera takes a picture automatically at set time intervals) a new folder is created for each series of pictures taken in this manner.
So the question is: what method are you using to view the pictures?
  • Do you remove the card from the camera and use a card reader and the computer's file manager to access the pictures, or
  • Do you leave the card in the camera, connect the camera to a computer through the USB cable and use the Nikon software supplied with the camera to view the pictures?
If the latter, the problem might be with the settings and/or peculiarities of the Nikon software.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
freda zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 15
Altijd: 1,053
