Ga door naar hoofdinhoud
iMac G4 17" 1,25 GHz Model M9168LLA PowerMac 6,1 geïntroduceerd in 2003.
Is the ATA bus bad?
I have a iMac G4, 1.25 GHz. The optical drive and hard drive have stopped working, and replacing the hard drive with a new 160 GB drive did not help. When trying to install OSX on the new hard drive, from an external optical drive, Disk Utility does not even see the new hard drive, and System Profiler says there is nothing on the ATA bus.
The computer works fine off of an external hard drive.
Any ideas?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
Could be a bad
cable or connector some of these were notoriously easy to damage.
I have also seen mispinned connectons where one pin is bent or outside the strip.
If this answer was helpful please remember to mark it accepted.
Good Luck,
N
Was dit antwoord nuttig?
Score 1
1 Opmerking:
+ ok
door
Voeg je antwoord toe
Bob zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 25
Altijd: 1,547
