Ga door naar hoofdinhoud
Reparatiehandleidingen voor de MacBook.
3787 Vragen Bekijk alle
Vraag afgerond
Why won't my MacBook respond to the power button at all?
My macbook won't respond to anything when i try to power it on. The power adapter is working and show's green (and amber when the battery needed to charge so now the battery is fully charged. When i press the power button to turn it on, literally nothing happens. I hear no noise whatsoever and I tried to reset the PRAM, but no response.
Took off the top case and it's secure to the logic board and i never spilled anything on it or dropped it so i'm not sure why it just died and won't turn on.
Obviously with the computer being made in 2007, i no longer have a warrantee so i don't want to pay Apple to fix it if it's something I can do myself, having repaired apple products.
Any help would be great
Is dit een goede vraag?
Voeg een opmerking toe
5 Antwoorden
Gekozen oplossing
Afbeeldingsinhoud bekijken:
Was dit antwoord nuttig?
Score 3
The logic board does not seem to be getting the signal to turn on. I have to suspect the keyboard and keyboard cable, which you did. Time to go to a tech with a spare keyboard to find what has failed. Sorry to tell you this but it's the first thing I would do is connect a known good keyboard.
Score 2
1 Opmerking:
Here is a picture of the jump pads. If the MB starts after shortening them you'll need a new topcase, as there are no replaceble parts.
Score 1
This is a common fault. You need o replace the top case/keyboard.
Hi there,
I encountered the same problem. After some research in your helpful forum (thanks) I managed to jumpstart (short circuit on the logic board) the macbook and reconnect the topcase/keyboard. Once started, the keyboard and trackpad are perfectly working, only the power button isn't.
Is there any way to test/repair/clean the power button rather than replacing the whole topcase and keyboard unit?
Thanks
roberting
1 Opmerking:
Robert, if you wouldn't mind please cut and paste this into a new question as it is a unique problem and I would like to have it searchable later for other to see. Thanks also the last three figures of your serial number (found in the battery compartment)
door
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 2,909
