Ga door naar hoofdinhoud
The 2014 version of the Galaxy Note 10.1", running a Exynos 5 processor and 3 Gb of ram. Released October 2013.
119 Vragen Bekijk alle
How do I replace the charging assembly on my Note 10.1?
The current port will no longer establish a valid connection even when I use a new cable. I've purchased a New Charging Assembly from IFIXIT and I need directions to change it out. It is a Galaxy Note 10.1 (2014, WiFi)
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi,
Here are two videos which may be of some help.
This one (which is actually to show how to replace the battery) is good because it shows how to open the tablet and also how to release the charge port flex cable from the systemboard. It doesn't show the removal of the charge port however.
https://www.youtube.com/watch?v=y7PP4tCJ...
This one, of lesser quality, actually shows the removal and replacement of the charging port.
https://www.youtube.com/watch?v=uVNCdPoR...
If you watch both first, no doubt you will have a good idea of what you need to do.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
sueraebell zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 423
