Ga door naar hoofdinhoud
The Syma X5C is a four-channel quadcopter with a built-in camera.
broken sprocket teeth repair
one of my motors has had two sprocket teeth break on the smaller sprocket on the underside of the motor. is there any way to repair that and if not is there a guide on how to replace that part?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Hi,
Here is a link to the Syma website X5C replacement parts page. You may be able to find exactly what you need here.
http://www.symatoystore.com/Syma-Spare-P...
Hopefully this is of some help.
Was dit antwoord nuttig?
Score 3
There is an epoxy that's been around a long time and well respected due to it's abilities to permanently repair broken metals, after it hardens it's even machinable.
"J-B Weld" can most likely repair the gear for good. Comes down to how well can you shape/machine the sprocket to match the others.
It's available almost anywhere, auto shops for sure.
Score 2
Voeg je antwoord toe
Infmaous xx89 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 1,721
