Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
What is my iPhone dying so quickly
When using my iPhone I usually charge my phone to 100%. However my phone tends to die around 70% to 90%. Then after a few minuets I turn it on to find it at around 70% to 90%. When it's not connected to a charger it would turn off right after the device has been powered on. i drained the battery but it would again power off if no charger is connected to the phone. I was wondering if I should buy another battery for the iPhone 6?
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Hi Eric
What may be beneficial for you is to contact a Apple Support Rep and get them to run diagnostics for you.
If your battery fails, then you can consider replacing the battery.
It is a common misconception that it is "good" to discharge your iPhone battery , lithium-ion batteries found in iPhones should not be discharged to the point of zero, it will shorten the battery life of your iPhone.
Regards
Brayden
Was dit antwoord nuttig?
Voeg je antwoord toe
Eric Del zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 6
Altijd: 126
