Ga door naar hoofdinhoud
Repair information for the 4th generation iPad. Released November 2, 2012. Model numbers: A1458, A1459, and A1460.
408 Vragen Bekijk alle
iPad 4 Completely Dead?
Hi Everyone
I've got an iPad 4 sitting here which i'd like to try and get working again.
It was brought to me and simply wouldn't turn on. No drops or liquid damage , never been opened.
I've cracked it open and replaced the charging port. Still no good!
I've also got a spare iPad 3/4 battery (which I believe is compatible? However despite this battery being charged , I still couldn't get any signs of life out of the iPad.
Is the logic board totally dead? Would appreciate some suggestions on this one!
PS: I also have an iPad Air with exactly the same issue but I think that needs a new charging port and i'm not very good with a soldering iron :P
Thanks!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
iPad Air charger port uses a charging port flex assembly that is basically a daughterboard that plugs to the logic board. So you will not need to do any soldering for that one.
Now for the iPad 4, this is almost certainly a component IC that has shorted / gone bad. Power Management IC is most likely at fault.
Here this webpage may be useful for you in the future:
http://mendonipadrehab.com/entries/gener...
Was dit antwoord nuttig?
Score 4
1 Opmerking:
Great thanks for the link! :)
door
Voeg je antwoord toe
Alex S zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 2,324
