Ga door naar hoofdinhoud
Repair and service information for the Sanza Fuse, a flash-based Video/MP3 player with a 1.9" color screen, and MicroSD slot. Released in March 2008.
15 Vragen Bekijk alle
Why does my fuze turn off when I turn it on
why does my fuze keep cutting off? i turn it on and it says something about stand by mode and cuts off. if i get it to play it stays on for a moment and blacks out
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi,
Have you tried to reset your player?
Here is a link that shows how to do it. Scroll down to find the procedure applicable to your model.
http://kb.sandisk.com/app/answers/detail...
If that fails to solve your problem, you could try and see if there is a firmware update that you can load into your player to see if that solves your problem.
Be aware that doing a firmware update can sometimes erase all of your data and it will restore the device to a factory default condition. If you can, copy your data before you try this.
Here is a link that shows you what to do.
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
will4emil25jr zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 99
