Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Model A1137 / 1, 2 of 4 GB capaciteit / zwarte of witte plastic voorzijde
Not responsive to trackwheel.
Powers On ok, but that is all it does. Cannot scroll to any menu.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Gekozen oplossing
Probably needs a replacement clickwheel or there is liquid damage to the unit causing it to behave erratically.
Was dit antwoord nuttig?
Score 1
does not respond to the trackwheel.
Only showing 1 song and plays only that song.
Has not gotten wet.
2 opmerkingen:
Have you tried to reset your iPod? Have you tried to connect it and checked with iTunes how many songs you have on there as well as the format of the songs? Have you tried to play them through iTunes? Does your click wheel allow you to make any menu changes?
door Deel
I'd too say that. Furthermore, I dunno it's a related issue, but the iPod Nano recently got a recall, still active AFAIK, because of heat issues with the battery, with melting plastics as a possible end result.
Maybe I'd give that a check.
door Deel
Voeg je antwoord toe
mcarmi2k zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 15
Altijd: 3,049
