Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
No Cellular Service On Phone
My iPhone 6 has been having some issues with it's cellular service. The phone will say no service, and so I turn the phone into airplane mode to restart the signal. The phone will continue to search for service, but won't pick any service and just continue searching.
Before I would restart all setting and this would fix the phone for a few days. Now I tried to do this and my phone won't pick up anything. I can pick up wi-fi and bluetooth fine with zero issues. I reset all my settings and content as if it was a brand new phone and it still doesn't work.
Is there any way to fix this? Also if I need a part to change out what would I need?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Hi
Try replacing the signal antenna and see if this improve the signal.
Signal antenna is coming with charging flex. See photo:
Good luck
Was dit antwoord nuttig?
With a sim inserted.
Go settings > general > about can you a iccid number?
1 Opmerking:
I have the similiar issue. And I can see a iccid number. What to check now?
door
Voeg je antwoord toe
spcrandall0403 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 446
