Ga door naar hoofdinhoud
MacBook Pro-modellen met een 15" scherm
8251 Vragen Bekijk alle
How do I fix a sticky space bar
i recently spilled cola on my keyboard and the space bar seems to be sticking or not bouncing back as fast as i used to i was wondering if i would need to remove the key and clean under it or would i have to go to the apple store to fix it
also i don't know how to remove keys from the keyboard i would need some advice on that thank you.
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
Here's a YouTube video that should help:
How to remove and clean Macbook Pro keyboard keys
https://www.youtube.com/watch?v=LCT-CldP...
Good luck!
Was dit antwoord nuttig?
Score 2
I recently ran into this myself... sticky space-bar. I pulled off the key and cleaned up all the junk from 8+ years of use, but reassembly didn't help (in fact made it worse).
I ended up using some spray lube on the metal bars (after some trial and error). Seems all better now.
Score 1
1 Opmerking:
Wow another victory for Tri Flow lubricant.
My space bar was getting a bit sticky and making things slowwwww.
On my almost 10 year old early 2008 Macbook Pro (Penryn), I couldn't figure out anything to do after replacing the spacebar with newer used version.
So I took you advice and gave it another look and cleaning with the Tri Flow lubricant on the metal bars and well, there ya go, better.
door
Ehm, here's a tip. Next time, be more cautious. DONT &&^&^$^ DRINK COKE
1 Opmerking:
Man. If only they would have thought of that sooner. Shucks scoobs.
door
didn't work please help!@45334543534
Voeg je antwoord toe
Kat Wardlaw zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 23
Altijd: 46,681
