iPad 2 in a boot loop after a battery disconnect and reconnect
I replaced the back cover on iPad 2 and exchange all components to new cover including some being replaced new. When finished I power up to test all functions. I got a good boot and home screen but in less than 2 minutes in went into a boot loop with about 1 minute delay after boot before home screen appears then 1-2 minutes and boot loop and won't stop. Any suggestions?
Is dit een goede vraag?
2 opmerkingen
Have you tried charging it for like an hour or more while turned off if possible?
door Ben
I was able to fix it, what I did was go back and remove the logic board disconnecting the battery clean the battery contacts with alcohol allowed to air dry and reassemble. it worked perfectly no more problems
door Danny Hartley
