Ga door naar hoofdinhoud
Late 2011 model, A1278 / 2.4 GHz i5 or 2.8 GHz i7 processor.
591 Vragen Bekijk alle
Vraag afgerond
MacBook Pro not booting after manual SMC update
Dear all,
To be synthetic:
I had kernel_task running over 300% with my HDD WD Blue
I replaced it with a SSD and the problem was still here...
I looked up into settings and found that i didn"t had the correct SMC and EFI version: see below:
Nom du modèle : MacBook Pro
Identifiant du modèle : MacBookPro8,1
Nom du processeur : Intel Core i5
Vitesse du processeur : 2,4 GHz
Nombre de processeurs : 1
Nombre total de cœurs : 2
Cache de niveau 2 (par cœur) : 256 Ko
Cache de niveau 3 : 3 Mo
Mémoire : 4 Go
Version de la ROM de démarrage : MBP81.0047.B2C
Version SMC (système) : 1.68f99
https://discussions.apple.com/servlet/Ji...
As you can see i dont have the correct SMC installed, and have an unknow EFI ... I dont know how i have the wrong SMC and EFI ..
I tried to install the correct SMC and EFI from el capitan but it said that i needed 10.9.5 version, so i moved on and downgraded to mavericks and when i tried to install i got a message that i can't upgrade the version ... (or it was not needed )
I tried to flash the SMC with rEFIt and it has succeed:
I used the 201MBP13.smc which is located on the .pkg of the MBP late 2011 update here:
https://support.apple.com/kb/DL1474?loca...
Ofc i have a blackscreen so can't do anything..
Tried SMC, PRAM reset, nothing
Now when i'm booting, the fans starting at full speed 10 second after the boot, then turns about 6-7 seconds and then the mbp shut down ..
The mbp is out of waranty
Thanks for the help!
MacBook Pro, OS X Mavericks (10.9.5), 8,1 late 2011
Is dit een goede vraag?
2 opmerkingen
upupupupupupupupupupup
door
Up
If anyone have any answer about that ^^
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Hi,
Nothing worked for me, even the firmware restoration CD.
I manage to fix it: I had the 2010 SMC installed, so i took the smflasher.efi from the 2010 bundle, and the .smc from the 2011 bundle, then i flashed it with refit and it worked!
Thanks!
Was dit antwoord nuttig?
Het nuttigste antwoord
Dear Martel,
Firmware (including SMC and EFI) MUST be updated from AppStore, that's most stable version of SMC and EFI. And well, both are stored in MacBook's ROM. Don't worry first, you still have second chance because Apple Service Center has "Firmware Restoration CD" which able to repair almost all mac product's firmware
Sincerely,
Athaariq Ardhiansyah
Score 1
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 2,105
