Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
1233 Vragen Bekijk alle
I get a screen problem when turning my phone on .
When I turn on my phone the screen shows a narrow vertical line from the bottom and then spreads to the bottom third of the screen.
Is this a screen problem or a hardware fix?Any help would be appreciated.
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
What happened prior to this. Have you replaced the screen? Is this a new screen ? If so then you may find it's simply a faulty screen to start with
Was dit antwoord nuttig?
3 opmerkingen:
No the screen has not been replaced,it happened after a heavy shower of rain and it was in my pocket.Although it was damp it was not dripping in water.
door
will need opening up and cleaning John. too much of a coincidence and looks like you will need a new screen also. the longer you leave it without cleaning then the less chance of saving it
door
Ok thanks for that I will give it a go.
door
Voeg je antwoord toe
john byrne zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 159
