Ga door naar hoofdinhoud
Google-branded tablet with a 7" screen. The device needs only prying tools and screwdrivers to fix. Model number: ME370T.
Touch screen will not work
After the tablet was dropped the touch aspect of the screen will not work. The tablet will power on and screen is normal and via able but I can't do anything.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi,
The digitizer (touchscreen) has probably gone faulty and it will need to be replaced.
Here is a link that shows how to replace the LCD screen and the Digitizer. They are glued together and although they are able to be separated, without the equipment necessary to do this it is better just to replace them both, as it will probably be easier to do as well as cause less damage.
https://www.youtube.com/watch?v=t2O5Dt1I...
Here is a link to just one supplier of the parts. It is not a recommendation to use them. It is merely to show what options are available. If in doubt about which part is the one you need, contact the supplier for further information
http://www.etradesupply.com/catalogsearc...
Hopefully this is of some help.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Wendy Sizemore zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 808
