Ga door naar hoofdinhoud
Ook wel bekend als de Moto G3: een Android-smartphone die in juli 2015 door Motorola werd uitgebracht. Het dient als een zuinig alternatief voor de vlaggenschiptelefoons van Motorola. Model XT1540 in de VS, met dual-sim- en "Turbo Edition"-varianten die in andere regio's worden verkocht.
How to I replace the Screen and backing?
So, my phone slipped out while running, then I slipped on it. Half the screen is black. Amazing the touch functionality still works, I just can't see it. I can still text and talk with some maneuvering and know how.
How can I replace the backing of the screen? I am impressed with the gorilla glass as the screen itself is fine (after taking my full bodyweight!)
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Gekozen oplossing
Hey james, Holger is correct in saying that the whole LCD display must be replaced since the glass cannot be easily removed from the backing. Also, I believe that the new LCD and glass will already be attached together when you purchase the replacement.
A guide for replacing the LCD screen has already been written but will not be visible until iFixit publishes it. It should be viewable sometime in the next two weeks. When it is available, you should be able to find it with this link: Motorola Moto G 3rd Generation Display vervangen
Good luck!
James
Was dit antwoord nuttig?
Score 2
Hi James,
That, I believe, is a bonded assembly. Replace the entire display assembly. There is no guide for that phone here but I suspect its mot that far away from the 2nd Gen. Motorola Moto G 2nd Generation Demontage
Good luck
Holger
Score 1
Voeg je antwoord toe
james James zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 36
Altijd: 801
